Yes this is correct. The inspection has been done. All that has to be done is fix the list of discrepancies. If you watch or listen to that webinar I posted he states this. The inspection has been done, it just has some discrepancies. Fix those and you do not need another inspection, its been done.
Correct based on what? A webinar? Is it possible the webinar information is incorrect?
Can you point to instructions in the operating limitations that instruct one on how to sign off a condition inspection with discrepancies? Bueller? Bueller? Anyone?
How does one sign off a condition inspection when one of the "conditions" that must be met is that the aircraft be in condition for safe operation?
