There is no such thing as a "major repair" (as defined in part 43) on a homebuilt.
Well, yeah, not necessarily as defined in part 43, Appendix A, but my Op-Limits explicitly state:
After incorporating a major change as described in Part 21.93, the aircraft oner is required to re-establish compliance with Part 91.319. Blah, Blah, Blah..., here's how to do it..."
Now, Part 21.93 says:
(a) In addition to changes in type design specified in paragraph (b) of this section, changes in type design are classified as minor and major. A "minor change" is one that has no appreciable effect on the weight, balance, structural strength, reliability, operational characteristics, or other characteristics affecting the airworthiness of the product. All other changes are "major changes" (except as provided in paragraph (b) of this section).
Obviously, there are no changes in "type design" for E/AB aircraft, but there are major and minor changes as defined in the second sentence above. So, _IF_ some change to the E/AB aircraft, after the original AC is issued, has no appreciable (where "appreciable" is obviously open to some interpretation) effect on the <stuff listed above> then it's minor and needs no compliance action as listed in the Op-Limits. But if it DOES have "appreciable" affect, then it's considered a "major change" and compliance must be re-established per the OL's.
Not knowing exactly what Dana is proposing, it's hard to say whether I'd consider it major or minor, but let's say it's major. If the inspecting A&P believes the repair/fix/change to be SAFE, he signs off the CI. Then Dana uses the procedure in his OL's in re-establishing compliance with 91.319.
In either case (major or minor), the only difference is in whether Dana needs to re-establish per the OL's - the A&P only needs to determine whether what he sees after the work is done is SAFE.
Good luck Dana but I don't see this turning out positive. I'd get another A&P to do the inspection.
Agreed.
