You do understand about Reynolds numbers and the like? Power and lift do not scale linearly with size.
Yes, I am a mechanical engineer with a extensive background in aerodynamics. I have chosen a tried and true high lift (ultralight) airfoil with the stall characteristics where I need them and I am OK with the higher drag it has as I am not going for speed. My calculations and double checking with NASA calculations, for the final projected weight the stall speed in airplane mode falls within 18.2 and 20.4 MPH.
The aerodynamics, construction and flight characteristic are not where I need the help, it is the electronics, flight controls, batteries, etc. I have researched all of this and have found various sources.
I am in need of an experienced person to help me wade thru all the info, etc. and choose wisely...
Thank you for the response. I hope you can help me.
