You might end having to develop all the numbers yourself, as if this were a newly-completed aircraft. This could be pretty fun, and will help you get used to your new airplane. FAA Advisory Circular AC-90-89B ("Amateur-Built Aircraft and Ultralight Flight Testing Handbook") is a good guide.
https://www.faa.gov/regulations_poli...mentID/1027429
I've written a template for a Pilot's Handbook for the Bowers Fly Baby, a similar aircraft. Here's a PDF version:
http://www.bowersflybaby.com/POH.pdf
I've also put it online as a Word document if you want to use it as a template for your own document
http://www.bowersflybaby.com/POH.docx
