Quote Originally Posted by flyrgreen View Post
As Airmutt says, coastal air is very salty. He mentions airframe corrosion, and that's something to watch for. But electrical connections are also very prone to this same corrosion. Headset jacks, push-to-talk switches, paddle connectors in the battery area and behind the panel, etc. These will need to be sprayed with electrical contact cleaner from time to time.
If the coastal area is in the Florida to North Carolina area, you will also need to be familiar with repairing hail & tornado damage. Just sayin'........
What I don't quite 'get', especially about electrical issues, is my car is parked outside about the same distance if not closer to the ocean than the airport I have in mind and shows very little effect from being there and modern cars are nothing if not dependent on electrical connections to make their way through the world..
