Quote Originally Posted by cwilliamrose View Post
I wish I had seen this while I was still at the shop. But just looking at it I don't see why it's not a straight forward fillet. You should be able to select the intersecting line and create the fillet. Sometimes SWx gets fussy about the fillet radius but this doesn't look to be that type of a problem. In any case once the intersecting line is selected you can play with changing the radius (start small). Also, try just one fillet at a time until you get something that is acceptable, then try adding other intersecting lines to the selection set. Sometimes SWx forces you to use multiple fillet features to get all of them you need into the model.
Sigh (and slap my head).
I'd been selecting the aft face of the oval area, AND the side of the table area, or the vertical line AND the aft face of the oval area. Never considered just clicking the vertical line only.
And yes, that did the trick. Thanks!
Just got done printing the fillet-less version on the 3D printer. If it breaks coming off AGAIN, I'll do the filleted version.
