The Mosler in my Fisher 404 had the tach connected to (and powered by) the P-lead, worked just fine. There was a fuse in the line as the tach manufacturer specifies. I don't see a problem with it.
And if you have a shielded ignition as I did, a Tiny Tach wouldn't work anyway.
