Originally Posted by
wa4eio
So far no one has mentioned the PTS and it’s replacement the draft ACS. I would print out the new ACS when it is released or even the draft proposal. Then in the space between each task, I would write in what I did to satisfy the task. The tasks can be satisfied by either physically performing them or through book work. If an A&P or IA can sign/initial each task as you do it, you will be showing the FAA that you made a professional and structured effort. If it is by book work, the A&P or IA can indicate the they discussed what you read.
Discuss this his with your local FSDO. Building a kit plane doesn’t prove anything. Individual tasks, as they line up with the PTS or ACS, are what is needed. Just my opinion.
