Results 1 to 10 of 44
Thread: Getting your A&P
Threaded View
  1. #10
    Jul 2018
    Quote Originally Posted by jam0552@msn.com View Post
    One other thing was an issue for me- turbine engine experience for the "P" rating. I got plenty of reciprocating engine experience but turbine engines are so valuable and scarce, that only accredited schools have engines to work on/study.
    Joel Marketello
    It still amazes me that the FAA hasn't split up the Turbine and the Reciprocating Power plant rating, it makes zero sense to have them combined, they share nothing in common except a propeller if it is a turbo prop. I just don't understand the lack of logic. I remember in the past hearing about ex military jet guys trying to get P ratings that had zero recip experience so it so makes sense to make them separate ratings. Jet mechanics never deal with magneto timing nor cylinder pressure differential tests etc.
    One other question all I see is A&P rating here, cann't you still get one or the other alone? And what about an AI or IA what ever it is called now, can that be also had for one or the other? And then where does power plant stop and airframe begins, at the mount to fire wall? Or engine to mount?
