I understand what you are advocating and am sympathetic to the novice builder who doesn't have the technical background of the gray-beards. There are two obstacles to inexpensive homebuilts that immediately come to mind:
1) The desire for immediate gratification with the latest and greatest flash and bang. Yes, the legacy designs have their own charm but not the appeal of new aircraft. This desire to have strong performance, quick builds, and the latest tech drives the community of builders into the "$40K kits".
2) The lack of a reliable, field-proven, low-cost and readily available powerplant in large quantities. The $7000 aircraft doesn't happen because there is no way to fill these powerplant needs in this price range. A decent used Conti or Lyc is going to consume that $7000 budget with nothing being spent on the airframe, and good used engines are becoming quite rare. The "alternative" engines are plagued with low-time field history/reliability and often sketchy support.
I wish we had a good solution to your question but I suspect it is just going to be necessary to raise the $$$$$ bar to achieve the reliability and performance desired.......and the market has already done that.
