You need an Airworthiness Application. It lists all options. Pick the category you think will work and study what is required.
The FAA will likely not approve any option other than Exhibition, is my guess.
Exhibition has operational limitations.
A damaged aircraft can be repaired by following repair procedures because it already has an airworthiness certificate. If you buy something without an Airworthiness Certificate, it might not be possible to get one. Do the research. It isn't simple.
