Results 1 to 10 of 32
Thread: When is an Ultra Light not and Can it be a LSA
Threaded View
    Sam Buchanan's Avatar
    KDCU
    My point is that I'm not aware of any regulatory obstacles to obtaining an experimental airworthiness certificate for a flying ultralight IF all paperwork is in order.
    I built a Legal Eagle and the build was documented on my website, in a detailed log......and a highly regarded magazine. Since the LE is a plans-built aircraft, and documented as amateur-built, and I could sign notarized affidavits stating same, there are no differences in this case of presenting a flying UL from when I presented my fresh non-UL Fokker replica for inspection. The fact the LE was already flying is a non-factor because it was an ultralight with no prior inspection required.
    We need to resist the urge to create defacto regulation where it doesn't exist.
    Sam Buchanan
    The RV Journal RV-6 build log
