Glenn,
Thank you for the suggestion. Their web site does not provide much product information but I did ask for a quote. I will soon need to do a weight and balance to see if I can use a carbon fiber prop. Addressing CG concerns is a real issue as the plane has a pertinacity to be tail heavy and a 51 pound Hartzell prop would take care of that issue but so would a larger batter in the engine compartment.
I appreciate the reply, Thanks again.
