Hi guys and gals,
2/5/17, Wow, this is cool. Big pieces of the plane. Both right and left side of the basic undercarriage legs. I do have to bend some 2 mm 4130 for the two U shaped clips that get welded in for the bracing wires and this week I will make templates and cut 1 mm 4130 for the bungee cord assemblies that weld on each side of the axle blocks. The actual bungee tubes should arrive in 3 weeks.
The welding went flawlessly. There was hardly any movement in the position of the ball forks in the jig. They didn't even move the entire 3/16" I allowed for. Thanks Jeff, best to be safe and sage advice.
D VII
:work:
Name:  Fok undercarriage legs.jpg
