Don't know about "safety"; seems to me that few folks flying an open-cockpit plane really need any sort of electronic devices to ensure their safety.
The problem is, it doesn't really eliminate the big drawback for flight use of this helmet: Noise attenuation. Modern headsets do a much better job at eliminating the engine and slipstream sounds. I found this when I converted an old Russian leather helmet for GA use...yes, the speakers were right by my ears but the background sounds weren't really reduced much.
I fixed that issue by wearing high-attenuation ear buds under the helmet, and not bothering with the in-helmet speakers at all. I'm using Plugfones in my Fly Baby right now...
https://www.plugfones.com/
They have ~25 dB of attenuation, about the same as a headset. You would need a simple impedance matcher to use them on a standard aircraft radio, but they're just fine on a handheld with 8-ohm output. They fit easily under the helmet.
