I have no doubt that epoxy can be stronger than wood, but:
I want some Weldwood, so 20 min to hdwe store and $10 and I have it. For epoxy, mail off a chunk of bucks to ACS and wait for it to arrive.
To use the Weldwood, pour a tablespoon or so into a dixie cup, mix with water and an icecream stick and use.. Clean up afterward with a damp paper towel. For epoxy, isolate building area from the rest of the house to block fumes. Don gloves mask and other protective gear as required, mix ingredients as required, glue parts, clean up with acetone..
In the end, each way gets the same result, a well glued joint. Why bother with epoxy?
"Works with less than perfect workmanship", = you can get away with sloppy workmanship. Not a message I want to hear in aircraft construction..
