Results 1 to 10 of 16
Thread: EAB that qualify as light sport
    wallda's Avatar
    Aug 2014
    Central Wisconsin
    I did not want to hijack the very good thread on EAB vs LSA. Is there a list of EAB aircraft that can be flown under sport pilot?
    If not can we start one?
    “It's the greatest shot of adrenaline to be doing what you have wanted to do so badly. You almost feel like you could fly without a plane.”
    -Charles Lindbergh
    Nov 2012
    Its a weight thing, speed thing.
    Fisher Flying Products all fit into this class, as do Mini-max's. Most your Rans if not all Rans aircraft can be flown SP. Some Sonerai's fall into the SP class. The two seat stretch low wing is one. Some build and fly these as SP.
    That's about all off the top of my head I can think of but there are many many more. Just all that come to mind right now.
    Tony
    wallda's Avatar
    Aug 2014
    Central Wisconsin
    I am particularly interested in older designs.....
    -Charles Lindbergh
    Nov 2012
    When you say older you mean airplane design older or a company that has been around a long time?
    Look at Dawn Patrol. That is an Old design.
    wallda's Avatar
    Aug 2014
    Central Wisconsin
    Older as in aircraft that were designed in the 60s, 70s, and 80s. Aircraft that were designed and plans built...
    -Charles Lindbergh
    Fly Baby, Pietenpol, Volksplane, Cuby and variants... I'd guess more than half of all homebuilt designs would qualify as LSA.
    Nov 2012
    Tony
    Quote Originally Posted by wallda View Post
    I believe those I posted fall into this group....
    Lets see the Sonerai was designed in the 70's.
    All the rest I mention was designed in the late 70's or 80's.....
    Tony
    CarlOrton's Avatar
    DFW Area
    The original poster wanted a list of EAB aircraft that could be flown under Sport Pilot. Then the request was changed to request older designs that could be plans built.
    Just to be complete, the Sonex line of aircraft (Sonex, Waiex, Xenos, Onex) can all be flown by a Sport Pilot. All are kits except for the basic Sonex, which can be plans-built (as in, you buy all the raw material and fabricate your own parts, down to welding the tube components) or kit built.
    I believe some of the older Zenith designs may be SP compatible, but I wouldn't wager more than a Coke on that information. I believe some of them are also plans-buildable.
    Carl Orton
    http://mykitlog.com/corton
    Banned
    With apologies to Jack Nicholson, "You wanna a list, you can't handle lists", but these come extremely close to ultimate lists:
    Firstly, here's the list of LSA qualifications:
    http://www.eaa.org/en/eaa/aviation-c...ort-pilot-rule
    Here's a list of FAA approved E-AB Kits:
    Amateur-Built Kit Listing - Federal Aviation Administration
    Here's a directory database of E-AB including plans-built that's quite exhaustive:
    http://www.pilotfriend.com/experimen...craft_list.htm
    All you have to do now is take the time to make a comparative analysis and then pick your poison. Be careful what you ask for and have fun.
