Nothing to do with the twin conversion. It has to do with someone thinking they know everything. I ran this A&P off. The gaskets hold the valve cover tight against the bail wire. Remove the gasket and the valve cover will fall off as it did me.
Ah, gotcha. It's been 15 years since I've owned a VW, but I remember the valve cover gasket was made of thick cork. Put something thinner in there and it'll be loose.
Thanks for the info....
