In the years since portable radios first used transistors, the issue of interference has gotten a lot of attention from the FCC (not FAA). Modern devices must pass Part 15 testing to show that they do not radiate, or conduct back into the power line, electromagnetic interference (EMI) that can disrupt the operation of other nearby electronic devices. The modern FCC standards have likely taken care of the issues that the FAA originally was concerned about. Interference events that occurred 30 years ago are unlikely to be repeated today as most of that old and electronically ugly gear went to the scrap pile long ago. That said, the FCC and the FAA are almost two different universes that barely intersect.
As noted above, the airline companies are extremely risk averse for obvious reasons and it will only be the profit motive that gets them to update their policies. So you should look forward to the day when the airlines figure out how to put a cell phone mini-cell in each aircraft and try to charge you for it. That event will bring down the barriers to using other devices and with the competitiveness of the airline industry, you can expect "reasonable" pricing for using your cell phone in flight. That pricing will likely limit the number of chatterboxes you get to sit next to, but let you call the family to let them know when your delayed flight is actually arriving.
