Depends on your camera and what altitudes you want to use. The STCs for 172/182's camera ports are usually limited to smaller format cameras. If you have a larger format camera you're going to have to go to the 206 or 208. The 208 has it nicely if you're doing higher altitude stuff but at 10K or whatever, you'll likely find the 206 much more economical.
