Wes, the idea that the jets are ready to go at the end is propaganda. For example virtually all of them only fly on ifr flight plans, it doesn't matter if there is not a cloud in the state, and it they are only going to Eagle about 15 miles away or Rifle 40 miles away. So they must have IFR clearance for takeoff and it is not unusual for that to take some time once they are ready at the end. And they will also often sit on the runway for few moments after being cleared for takeoff.
I could do a mag check while taxing, but sort of like texting while driving that is not the best procedure and not the safest. And there are other items on the just before flight check list other than just the engine run up. My check takes less than a minute, but the tower guys will give you the same line even if it is a slow day and there is not another airplane moving. And I am not using IFR service nor waiting for that clearance.
Here is Aspen they added 1000 feet to the runway length. Now some folks will claim there is a budget shortfall, but I can tell you there is no shortage of Federal funds for more concrete for such a runway or for more and new control towers, even if they have one already.
The longer runway gurus built the runway extension , but didn' t put a run up area at the new end. So now if more than one plane goes down to the end, it must sit on and block the only taxiway(actually, since there was plenty of money for concrete they even built a taxiway on the other side, but it doesn't connect to anything)
So the result is they try to get the piston airplanes to do without the run up and pre flght check at the end, The other issue is if you taxi all the way to the end and have to wait behind a G5 , their exhaust is coming right into your face, and I'll bet it is not healthy in a matter of moments.
I have never heard the phrase "ready reaching" used anywhere.
I don't fly jets but I doubt if the procedure for any major U S airline is to do their pre takeoff checklist while they are taxiing. Is it?
And I don't fly a turboprop,and I don't doubt that many of them may do their checklist while on the roll, and not repeat items for each takeoff during the day.
But if there was an accident that had anything to do with props not working right after takeoff, or even a trim or flap setting, and there was an FAA hearing or a civil court case and it was found that the pilots skipped this item on a checklist, what would be the likely finding?
