Thanks first for posting this interesting patent! You´re definitly right - looks quite a bit like our design. But I think our dream isn´t the newest at all - We´re just crazy enough to realize it...
Regarding your points -
The nose down moment of the engines is not too strong but calculated. It will have to be compensated by the pilot at lower speeds and depends very much on the flown speed, the wing will create a nose-up moment at higher speeds. The nose down shall also be some kind of a stall protection - Whenever something gets critical you can put the throttle up and the plane will recover. Due to your feet beeing in the engines jet-stream, you can apply a lot of force (for example at take-off) to annihilate this moment even without floating air around you.
Also, in addition to what you see at most CAD printings, the pilot has a V-tail mounted at his feet. This has quite a strong lever-arm to the force applied by the engines moment.
The pilots reaction on a dropping wing will be pretty much like the reaction of a hang glider pilot would be - bringing your center of gravity to opposite direction. If that doesn´t has enough effect, he can, different to a hang-glider, also put his arm in front of the leading edge of the upper wing - thus destroying the lift there, and move his legs creating a rudder effect with his V-tail. We already tried that out with the preliminary gliders :-)
Tests will start directly with the engines mounted due to the very important influence they have on stability and applied forces on the airframe. We will post a lot of details regarding the tests and controls later on our website.
I hope my english is understandable, don´t mind to ask!
Best regards
