Results 1 to 10 of 12
Thread: Kickstarting a Debate
    Banned
    Now that Cessna has decided to go Primary Category Certification for its Skycatcher LSA, could the Icon A5 Amphib LSA be close behind?
    Cessna is going Primary in order to seemlessly enter sales markets outside the U.S.(note: it will remain Sport Pilot eligible in the US). If Icon is not granted their LSA weight increase excemption request, would they too go Primary as a solution for currently being way outside the LSA gross weight envelope? Would such action have to seriously consider the one-third of their over 1000 deposit holders who currently hold no pilot license of any kind.
    And to further muddy or muddle the waters, if the 3rd class medical exemption is granted, a Primary Category Icon could be flown by a PPL without a medical. So much for the much cheaper SPL that would render the one-third depositers SOL.
    Also, could someone "truly in the know" please briefly explain exactly what Primary Category Certification is?
    Primary Category was introduced some 20-30 years ago, basically a simpler certification process than standard category but still a Type Certificate rather than the industry certification used by LSAs, and similarly limited by size and performance. As I recall, there was also more owner maintenance allowed, and it is possible for a one way conversion of a standard category aircraft like a Cub or T-Craft to primary category so the owner could do the maintenance. I don't think many Primary type certificates were issued... the Quicksilver GT500 is the only one I'm aware of.
    cluttonfred's Avatar
    World traveler
    Have LSA and Sport Pilot made Primary Category certification more attractive if the aircraft also meets the LSA definition like the older, lighter Cubs, Champs, Ercoupes, Luscombes, etc.?
    If I understand correctly, an LSA-spec Primary Category aircraft could be used for instruction and rental, could be easily exported as a type-certificated aircraft, yet could be still be flown without a medical in the USA by any pilot exercising Sport Pilot privileges. Also in the USA, amateur-assembled kits would still be allowed if under the manufacturers supervision, would not need to meet the 51% rule and would be equivalent to factory-produced aircraft once completed. The only limitation is not being able to carry passengers or cargo for hire--not a big problem for light two-seaters in any case. Am I missing something?
    [I am reviving this thread as a corollary to the Icon A5 Request For Weight Increase Exemption Status discussion.]
    Matthew Long, Editor
    cluttonfred.info
    FA40
    seems to make sense to pursue primary certification AND LSA concurrently. especially if the requirement for 3rd class for recreational pilots is dropped to "training in lieu", so to speak. and why couldn't they make separate hardware-similiar models with different paperwork certification levels? others do it.
    Sidney, OH
    Having read a couple of articles with titles like "The Coming Shake-Out in the LSA Market", I'd say that those LSA producers who can afford the certification process will probably move in that direction. The market for a brand new airplane that meets the LSA spec's is too small to justify all the makes and models currently offered. This is a case where competition doesn't drive price down. I'd bet that those players with "deep pockets" will remain in the business but many of the little guys will dry-up. This should have been obvious at the start, a lot of "investors" jumped-in early when the "market" thought that the aging pilot population would jump on the "no medical" required thing. If the "market" would have looked at the low level of "retirement" funds available to the baby boom generation they might have had second thoughts. Now we've got too many aircraft being offered with the same performance spec's and to too few buyers. We might see a few producers like Cessna pick-up a nitche player like say Legend Cub to gain a bit of market share, but most of the players are too small to play that game. The new aircraft market for single-engine GA is still limited do in part to a big inventory of used aircraft. It will take a long time to clear out the old aircraft.
    Joe
    zaitcev's Avatar
    Jan 2013
    The only other one is RANS S-7. C162 is the third attempt ever. Even Champ 7EC is still made under Normal category. IIRC the Primary existed when ACA replaced its spruce spar with aluminum one, but they kept Normal certification.
    One unpleasant thing about Primary certification rules is the prohibition of instruction. Basically it's the same problem that killed ultralights: they were converted into E-LSA, but one cannot instruct in E-LSA, only in S-LSA! Gotcha, suckers! FAA triumpfs again. In fact I think Cessna is going to continue to sell pink-certed 162s in U.S. just for this reason, and white-certed 162s will only be offered in Europe.
    (I'm quite aware that the language of the reg allows instruction in Primary aircraft "under special circumstances". Good luck proving to FSDO that yours are.)
    Banned
    Quote Originally Posted by Matthew Long View Post
    Matthew, thanks for reviving, it didn't get traction or too many eyeballs when I first posted it. Many developments have occured since in relation so perhaps more aviators are now more aware of the circumstances and implications.
    I believe the Chris Heinz company from Mexico, Missouri and Ontario, Canada, name escapes me now, certified one of their models as Primary as well about 15 years ago.
    World traveler
    Quote Originally Posted by zaitcev View Post
    The wording I saw is "certain circumstances." Since the Primary Category regs predate the LSA regs, and instruction and rental is allowed for LSAs, I wonder if there would be a case to be made for EAA, AOPA, etc. to petition the FAA to revisit that "certain circumstances" provision. Since the reg already allows for them to authorize those activities, it would be an easy fix and would make the Primary Category much more attractive.
    cluttonfred.info
    ... I believe the Chris Heinz company from Mexico, Missouri and Ontario, Canada, name escapes me now, certified one of their models as Primary as well about 15 years ago.
    The name you're looking for is Zenair, LTD in Midland, Ontario, Canada and the aircraft is the ALARUS CH2000, which has an FAA production certificate. The type certificate, TA5CH, doesn't mention it being a primary category aircraft.
    Bill
    Banned
    Thanks for looking that up Bill. Nonetheless another example of a major kit company going a certified route.
