Originally Posted by
aeromike49
As of Sept 13 2014 I was issued a special airworthiness certificate with no expiration date. Phase 1 testing of 5 hours and 5 takeoffs and landings to a full stop. Seems reasonable to me. The DAR came out and looked over the aircraft and paperwork. I have not been able to fly the aircraft (after 48 years of inactivity) as the wind has been excessive for a first flight. I spent over 20 hours on the paperwork. I created my own flight test plan - 5 pages worth. Also created several checklists, Several weight and balance sheets created with different weights, fuel loads and passenger weights, created an equipment list, and history of the aircraft All of this data was requested by the DAR. I had everything in a binder with tabs for each section. All of this worked well so the paperwork was readily available. I spent quite while documenting all the repairs and work performed in the aircraft and engine logs. The DAR commented that because of my background as an ATP pilot and A/P IA that the re-issue of the airworthiness certificate went smoothly. I had forwarded most all of the paperwork in advance so he had the opportunity to review the data before he came to look at the plane.
