Results 1 to 10 of 21
Thread: HBC Parking Into The Wind
    Jeff Point's Avatar
    Milwaukee
    Dan,
    As we discussed at the show, this idea is under serious consideration for next year among those of us in charge of the parking arrangements. We spent some time later in the week scoping things out and taking measurements to get a better handle on exactly what it would take to make it happen. Short version is that we could do it with reasonable efforts, mostly involving relocating some fences and remarking some burn lines.
    Before making any significant change, it is a good idea to carefully think things through and not just make a knee-jerk decision. Always beware the law of unintended consequences. Just to get discussion going, here are is some food for thought:
    Parking into the wind may be best for nose-gear RVs, but what about other types? Does pointing into the wind increase the risk for say a tailwheel RV, a canard aircraft, or a Cub-type which is now exposing it's high-lift airfoil to 60 MPH winds and straining it's tie downs beyond the failure point? A few years back we had an aircraft in HBP get ripped loose from it's tie downs in a storm and deposited upside down on top of the aircraft parked next to it, so it can happen. Does parking facing west increase that risk? Or the less extreme example of one being pulled loose from it's tie downs and pivoting into the adjacent aircraft, which has also happened.
    We have 11 months to hash this out and come to a decision, so let's have the conversation.
    Jeff Point
    RV-6 and RLU-1 built & flying
    Milwaukee, WI
    "It All Started Here!"
    Jeff, is there any data from the North 40, even if anecdotal? They park both ways.
    Dan Horton
    RV-8 Fastback
    Barrett IO-390
    Jeff Point's Avatar
    Milwaukee
    Quote Originally Posted by DanH View Post
    I dunno, but I know who to ask. Stand by for further…
    Jeff Point
    Milwaukee, WI
    Marietta, GA
    To lift an idea from "The Hunger Games", I think the odds would always be in our favor parked into the wind.
    1) In general, aircraft would be facing the prevailing winds and control surfaces would typically be in trail, reducing the chances of them getting slammed around.
    2) I think both nosegear and tailwheel aircraft, properly secured, won't go anywhere in strong headwinds. The aircraft I've seen wrecked at Oshkosh were all turned away from the wind and when the tail broke loose, bad things happened. Obviously, there are no guarantees that aircraft will be properly secured, but I think the odds are generally improved with the aircraft facing the wind.
    Aside: The nice little Sopwith Pup replica parked at the Replica Fighter Association HQ actually broke loose during the storm. I don't know why it didn't get shredded, but we walked up on it that evening, repaired the broken rope that had previously held the tail and tightened the ropes attached to the wings. The aircraft was secured by "the claw" and whoever tied it down didn't follow the instructions on how to use that system. Maybe someone needs to walk the field an hour after aircraft arrive and give tie-down guidance. There are people who could use help there...
    Gary.Sobek's Avatar
    NC25
    I have been going with the flow and parking as the volunteers request I park.
    Parking into the wind may help but if people do not have gust locks and take precautions to secure their flight surfaces I am of the opinion that it may not be enough. Over the years, I have gone from using gust locks outside the airplane to just placing the seatbelt around the stick. I have had my external gust locks blow off in strong winds. Yes there was one fatal accident where poor preflight did not remove the PAX seatbelt from the stick.
    Most likely there is not one single solution. Owner / operators MUST do what is best to secure their aircraft for gusty conditions and heavy precipitation. Just relying on direction of parking is not the complete solution but may be part of the solution.
    I know that the homebuilt parking chairman is looking out for the best interest of all of us but we still must do our best to secure our own aircraft.
    Gary A. Sobek
    EAA Lifetime Member
    A&P, Homebuilder, Pilot
    When once you have tasted flight,
    you will forever walk the earth
    with your eyes turned skyward,
    for there you have been,
    and there you will always long to return.
    - Leonardo da Vinci
    Dec 2011
    KUEL
    I havent flown in but is there a reason you couldnt swing you plane into the wind if you wanted to? Maybe with wet grass it would be difficult but who would stop you? I bet you would have a bunch of people do the same.
    Jeff Point's Avatar
    Milwaukee
    Quote Originally Posted by rockwoodrv9a View Post
    No reason at all. As long as you stay within the footprint of your parking spot, you can swing it around to face the other direction, and a few folks do so. We haven't really emphasized it but that is something we are also looking at for next year.
    Jeff Point
    Milwaukee, WI
    Jeff Point's Avatar
    Milwaukee
    Bingo. I see thousands of tie downs each year and a shockingly high percent are improperly installed, particularly "The Claw" which has become very popular. We try our best to correct folks who are doing it wrong but it often isn't caught until after the plane is tied down, and some folks just don't like to take friendly advice.
    I am convinced that many of the reports of "failures" of this system over the years were due to improper installation.
    Here's a photo from this year of a random RV in HBP. This owner put on a clinic on how not to install The Claw, but he is far from the only one.
    Jeff Point
    Milwaukee, WI
    Shiloh, IL
    I vote for parking into the wind.
    DSetser's Avatar
    Aug 2022
    New Hampshire
    I can't vote for arbitrarily turning everyone in HBC toward the west; Jeff Point's comment about unintended consequences is spot on. If I did my research correctly, peak winds during the Saturday storm were out of the south-southwest at 36G60ish. How much of that wind was the result of frontal passage and how much was outflow from the storm? I'd submit that outflow was a major contributor and could be very different during the next storm. If individual owners want to pivot in their tiedown spots based on their expectations of the wind, that's up to them.
    Seems to me that the better solution is education/awareness of selection and correct use of good tiedown *and* control lock solutions on vulnerable airplanes like big-rudder RVs.
    Dave
    ___________
    Dave Setser
    CFII/MEI, Consultant DER
    EAA Technical Counselor/Flight Advisor
    RV-7 N701ED Flying!
    Nashua, NH (KASH) / Plymouth, NH (1P1)
