Wings on temporarily. However, I have decided the wing incidence needs to be reduced. The plan dimensions end up with 4 degrees at spar centerlines. That seems way too much. After discussing with Robert Basley, I plan to reduce the incidence measurement down to about 1 degree. Unfortunately, that requires. replacing some of the vertical fuselage members. However, better to fix now tha after it is giving problems flying.
Dale
