Inching along on the left wing. The aileron torque tube hinges are now attached to the spar. The outer two can be removes to allow the aileron and torque tube to be removed. I also mounted the aileron control wishbone to the inner end of the torque tube.
Next step will be to cut the outer ends of the leading edge tube and spar to their final lengths.
Dale
