Are you priming the engine before you start swinging the prop. My a-65 starts on the first swing of the prop. I give it three squirts of the primer. Then pump the throttle three times to let the accelerator pump pump three times. I then keep the mags off and pull the prop through three times. Make the mags hot and she fires right up.
Tony
