Have a master brake cylinder,has -4 AN 833 elbow, What do i need for a hose with a out put end that will match 1/8 pipe thread? Need numbers for hose,fittings. Thanks.
Talk to the manufacturer as they probably have the information you are seeking.
Actually, I believe that the info that you need can be found in the Aircraft Spruce catalog. It is a great refererence about parts and AN/MS part numbers for the novice.
