Thread: MAP ignition curve
    Aug 2012
    Caracas - Venezuela
    MAP ignition curve
    I would like to discus with somebody about the adjustable MAP advance curve for the electronic ignition system. Mine is a double SDS electronic ignition system installed in a O-235-L2C (Rutan 61). I have a fix RPM advance curve that works very well (from 0 to 30 degrees at full RPM) but my doubts are in the MAP variation to adjust the correct curve with altitude. I have worked on some combinations from 8 degrees retard at sea level to a 12 degrees advance at 14000 feet, but I haven't actually tried it and I'm a little reluctant to use it until talk to somebody about it. Anybody?
    Chris In Marshfield's Avatar
    Germantown, WI
    Ross Farnham, "the SDS guy", hangs out over at the FlySoob group on Yahoo! forums. He'd be a great guy to ask the question to, and some of us over there with other engines might be able to learn a thing or two from your experience.
    http://groups.yahoo.com/group/FlySoob/
    If someone here doesn't have an answer for you, give it a try.
    ~Chris
    Germantown, WI
    Aug 2012
    Caracas - Venezuela
    Thank you Chris!
