I'm an experianced automotive/Heavy duty Diesel Technician, familiar with almost anything mechanical. However I'm new to aviation and composite materials. And I would appreciate some direction from experianced aviation enthusist.
I'm looking for a small plans built plane that I can mostly build in my garage, with my son. So that needs to fit 2.
I've been looking into the Rand Robinson KR-2. It seems to meet my needs and it's specs are appealing to me.
Does anyone have experiance with this aircraft?
I like the idea of the Corvair engine, and low cost and it's fuel economony makes it affordable.
I'm considering constructing it from all composites using a PVC Divinycell foam core, fiberglass, and epoxy resin.
I've been trying to find recommended procedure for using the PVC foam core but havent found one. Anybody have experience here?
Should I be vacume bagging components?
A guy has been constructing one www.krsuper2.com. Can anyone tell me if his design and building techniques are legitiment?
I'd like to follow his direction. I like the modern version of the KR-2.
Any information about these is appreciated.
