Results 1 to 4 of 4
Thread: Normal sequence oil loss
    Dec 2011
    Between use and throwing oil, I used about 5 qts in 30 hrs of flying what would be intermediate type sequences. Mostly, -2 to + 4 G little to no knife edge. Would this be considered in the norm?
    Hello,
    What model engine? Flying IAC Intermediate, in a Pitts S-2A with a Lyco IO-360-A1A (200HP) a typical practice flight is +6 to -3G. I fly practice hops of about 0.6hr and I expect to throw out a quart of oil every 3 flights. A typical practice hop includes at least one snap roll, at least one vertical roll up into a hammer, a rolling turn, and stuff like a loop, immelman with a 2x4 on top, and an upright or inverted spin.
    Hope this info is helpful.
    Dec 2011
    Very helpful thanks. I have a io- 360 as well. My oil loss is less than yours, so I'm not going to worry about it. I will reroute my oil breather to the underside of the fuselage, as it is currently coming out the side just above the rudder horn.
    Thanks again Wes
    Vernon, Britsh Columbia, Canada
    I fly an RV4 with a 0320 -= and I do aerobatics to 4G usually - ingelman's - etc... loops and rolls - etc... not too much in the way of inverted stuff - but I do verticle rolls - and cuban and reverse cuban 8's other stuff like that - I also do flights usually in about the .5 - .7 hour range - (darn price of fuel) - 1.77per liter here - anyways - I use approx. .5 liter of oil that's about 1/2 quart every 3 flights too. I was a bit worried at first but I think it's about normal and mostly due to the kind of flying I'm doing. You are doing more Neg. g than me - so likley you will loose a bit more - mine will blow out oil from the vent tube if I go neg for very long - say in a hammerhead that I did'nt time correctly for example. I will see it on the cowl after landing. I have learned not to do this so I don't loose as much now as I did when I first started.
    Quote Originally Posted by LJM View Post
    Thanks again Wes
