Falken Avionics Flightview Engine Monitor Modules for sale
I have two Falken Avionics Flightview Engine monitor modules for sale. Modules only.
These units were used approx 20 hrs each. While I can say they "worked" I was unable to get them to operate correctly.
I believe some of this was due to sender incompatibility as well as software bugs however due to a total lack of tech support from Falken Avionics it became obvious that I would not be able to rectify the issues, after much frustration and grounded plane I removed the system and installed an Electronics International CGR-30 which as well as working great comes with awesome tech support......not a "one man show"
These modules may be of use to someone who has the Falken Avionics Flightview System and is able to spend many months attempting to work with Falken Avionics to get these units operational.
These Falken Avionics Flight View Engine Monitor System modules are modules only.
