Results 1 to 9 of 9
Thread: Cessna 150 interior plastic
    May 2012
    Looking for early Cessna 150A thru 150C interior plastic panels.
    Columbia, IL
    www.planeplastics.com
    Pricey, but a great product.
    Jan 2016
    I remember reading an article years ago where repairs were done to these type of panels. May be an option for you.
    Basically they used some sort of putty or epoxy to make a mold of the texture pattern in an undamaged area. Then using that mold, they made the repair using an ABS slurry (legos or other abs dissolved in MEK). After painting, the repair was perfect.
    Early 150's did not originally have much plastic on the interior. Plane Plastics and Texas Aeroplastics are the most common suppliers of aftermarket interior parts.
    Banned
    Aug 2023
    You could also try the plastic panels from Revetements Agro in case you're looking for alternatives.
    Oct 2024
    Hello are still out for it I got one available
    Necro post much? You did notice this is a nearly NINE year old post?
    meglin's Avatar
    Aug 2015
    Kharkov
    Let me join in supplying plastic interior and exterior parts for these airplanes as well.
    Best regards, Vladimir Meglinsky
    My site: http://propeller.mozello.com/
    meglin's Avatar
    Aug 2015
    Kharkov
    During this time, a considerable need for interior and exterior parts for this aircraft has become apparent. We have some parts, but not all of them. Therefore, those who wish can send old or even damaged parts in order to receive new ones that are of much higher quality in terms of strength, rigidity, lightness, resistance to ultraviolet rays, humidity and temperature changes.
