#1 - I'm a tram conductor with 20 yrs experience up here at Oshkosh. Ever since the new Yellow/Blue and Yellow/Red were created, the tram volunteers have been complaining to EAA that exactly ZERO porta-potties get put in place at these much-used locations. Having NO quick access when Mother Nature calls is quite inconvenient to the workers AND all the would-be passengers. This has been causing frequent delays for the past 4 days, with no improvement in sight. Our complaints have been ignored by the powers that control such vital things. A further issue is that the porta-potty locations from all previous years have been changed removing most all convenient quick stopping points along the Blue route. Quite the hassle and illogical.
If EAA has no interest in the counsel of those who know the tram operations well, why bother wasting our time with end of show surveys?
#2 - A new parking lot has been created out by the South 40 bus/tram terminal. NO new necessary provisions were made to transport this massive new influx of attendees to the Main Gate or flightline. All the parking lots by the museum do have regular round trip bus shuttles to the main gate. Expecting the existing tram operation to simply absorb this large increase in passenger volume is unrealistic. Very poor planning IMHO.
#3 - Anyone with even slight familiarity with such things knows that trams and school buses should never be setup to share the same space and interchange passengers as they now must do at the crowded South 40 terminal. These machines simply CANNOT load/unload people at the same rate. As a result, trams are stalled in place as bus passengers slowly exit/enter the single bus door available. As a direct result of this physical reality, all trams behind the bus are immobilized, and the tram flow is stopped leading to several trams now backing up in a line ruining any hope of properly maintained the needed spacing of trams along the route. This needs to change.
C'mon EAA, you HAVE true 'experts' in tram operations at your disposal. How about using them for a welcome change to improve things? We don't need another pretty ineffective college student survey to sort things out. The improvements needed are VERY low cost, easy to implement and make sense. If history is any indication, that of course means they will never happen, which is a real shame.
End of this geezer's rant.
