ACS 131 key blank alternative Ilco LF12
I recently needed to have another key made. The key that fits my aircraft is an ACS 131. Apparently this is a common size. Finding these keys, turned out to be fairly expensive. After some research I found another blank that will work with your local locksmith. You can have several made for the price of one blank.
The key blank is: Ilco LF12
