Results 1 to 8 of 8
Thread: Help with FAA registration process
    I have a good friend in Mumbai, India, Amol Yadav, who has built an airplane on the roof of his apartment building. He is a commercial pilot there. He needs specific procedures that US aircraft builders have used to register their planes with the FAA.
    Amol has received extensive notoriety for his extraordinary efforts, which are the first of their kind in India. Here is a link to a recent newspaper article.
    http://www.thebetterindia.com/49385/...craft-terrace/
    Quote Originally Posted by Brad Nederhoff View Post
    Cool story. Not sure of what value it is but US builders of amateur built aircraft follow the guidance from AC 20.27G
    Is he actually trying to register the plane in the US, or is he going to use the US process as a template for dealing with the Indian equivalent of the FAA?
    He would prefer to use the US process as a template for obtaining approval with the Indian equivalent of the FAA, but if that does not work, he may register the plane in the US.
    Marty's suggestion of looking at Advisory Circular 20.27 would be the best thing, then.
    https://www.faa.gov/documentLibrary/...C%2020-27G.pdf
    Licensing it in the US would require an inspection by a Designated Airworthiness Representative (DAR), which are appointed by the FAA. He might have trouble finding one in India, though there may be some associated with other aviation enterprises there.
    Here's another good link that outlines what an inspector is going to look at when evaluating an aircraft:
    http://www.eaa.org/en/eaa/aviation-c...spection-guide
    If he's not a US citizen that might be a challenge. Home he can get homebuilt aircraft off the ground so to speak in India. That would be great!
    Jul 2024
    I need assistance with the FAA registration process for my drone. I've encountered some confusion with the online application form, especially regarding the required documentation and specific details needed. Any guidance on how to complete the registration efficiently or tips on avoiding common mistakes would be greatly appreciated. Thanks in advance for your help with navigating this process!
