Results 1 to 9 of 9
Thread: Guy without IA signing off annual busted
    Mar 2022
    Auburntsts's Avatar
    Tampa, FL
    Hmmm. Interesting case.
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
    Dec 2018
    While tragic this will only get worse, the FAA has made everything cost prohibitive by granting a bunch of little mini monopolies and making DIY stuff VERY difficult.
    Did this guy sign off his own plane or was he doing this for hire? Big difference, if it was his own plane he would have been better off just not doing an annual as there is no falsification then.
    The A&P/IA is particularly problematic as its quite onerous to get and every owner needs one and there are fewer and fewer IA's around to sign off planes which means prices go up, not everyone flying is a multi millionare.
    melann's Avatar
    Jul 2019
    N. Texas, Dallas Area
    Since much of the audience on this forum deals with Experimental Aircraft, it might be prudent to mention that IA is not required to sign off the Annual Condition Inspection for most Experimental aircraft.
    Mel, DAR since the Last Century, Specializing in Light-Sport and Experimental Aircraft. Certificated over 1,100 Light-Sport & Experimental aircraft.
    May 2023
    Quote Originally Posted by melann View Post
    I built mine and received the certificate to take care of it too. Not sure I could stand the cost of owning a certified plane and having someone else maintain it for me. ��
    melann's Avatar
    Jul 2019
    Quote Originally Posted by Dale Andee View Post
    Clarification: You, or anyone else, may maintain as Experimental Aircraft without the Repairman Certificate. The Repairman Certificate allows you to perform and sign off the annual condition inspection.
    May 2023
    Perhaps I should have clarified that point but glad you did. Yes I do my condition inspections and can still have an A&P put some eyes on it too ...
    Dec 2018
    What do you do about engine and prop work, its like pulling teeth to get things like constant speed prop overhaul manuals, if you subscribe then its thousands a year. I think the same goes for lycoming engines, luckily I was able to get ahold of the lycominb direct drive manaul but the parts seem to be problematic to buy (at least affordably)
    For those that know, how much more difficult is it to get an A&P vs a repairmans cert? I have heard the IA is not to bad as its just a computer test so if your good at tests it much better
    Eric Page's Avatar
    Toledo, WA
    Quote Originally Posted by akmetal View Post
    https://www.faa.gov/mechanics/become/experience
    Eric Page
    Map of Landings
