Thread: The easy way to measure epoxy
    Lightbulb The easy way to measure epoxy
    The easy way to manage T-88 epoxy – Dale's Biplane (botkin.org)
    I've been using 60 CC syringes for dispensing epoxy for the past several years. It's very easy, and you get very accurate measured amounts whether you're mixing just a little or a lot. I've now got three sets of syringes I keep in rotation just so I can get through several build sessions without needing to "reload", even if I'm mixing up pretty good amounts for working on wing spars.
    Jan 2012
    Thanks Dale, this is a good tip. I'll use it.
