Originally Posted by
JohnMyers
Some other problems I would love to use CFD for:
- determine if fiberglass fairings are worth the effort to construct in several areas. For example a wingtip.
- cowl design, or some simplified version of this
- heat flow in engine compartment after shutdown
- ducts and airflow for cabin heater
- ducts and airflow for air conditioner (I'm trying to put one in a Zenith, but that is another topic!)
- determine drag with/without wheel pants a different speeds
From your last point, it sounds like even assuming no prop, flow over the entire airframe would be impractical. What would the limit be, could a wheel with/without fairing be possible? !
