Thread: Electric Motor Controller
    Aug 2023
    Greetings - my first post on EAA forums!
    Question - I'm looking at purchasing a nice factory built motorglider with a DIY gas to electric motor conversion using a Rotex RET-60. The owner reports that the controller and inverter provided quickly failed. He's tried a couple other brands, same problem.
    Anybody have experience with controllers & inverters and can recommend a reliable source? The installation looks to be very well done but is it possible there are gremlins in the system elsewhere?
    My knowledge of all things electrical wouldn't wet a thimble so suggestions are most welcome.
    thanks!
    "War-Torn" Portland
    Paul Dye, Editor at Large for KITPLANES magazine, has just converted a Xenos motorglider to electric. I'd scan through his articles...
    Starting point:
    https://www.kitplanes.com/building-the-exenos/
    Video of first flight:
    https://www.sonexaircraft.com/first-...ul-dye-exenos/
    Aug 2023
    Thanks, I did a quick scan of the first article and noted that controllers need some firmware adjustments - which requires a rather skilled programmer.
    Any aversion to reverting the glider to a gas engine considering the e-failures?
    Aug 2023
    To be honest, all things considered I think I would prefer a gas engine.
    But - since this project is so close to the finish line, if the controller issue can be resolved, the electric motor would be perfectly ok.
    ironnerd's Avatar
    Nov 2020
    Atlanta
    Starting point:
    Is it prnounced EX-en-ohs or E-zee-nohs?
    I'm asking for a friend.
    John "J.P." Adams
    EAA 1379403
    I fly because it releases my mind from the tyranny of petty things.
    – Antoine de Saint-Exupery
