Any news about if cams are gonna be set up this year better than last year ?
Well last year it was briefed that the new strip was a several year project. They also told us that it was not economical to move the barn, so I assume there will eventually be a new structure. At this past work weekend they did brief work is still in progress but gave no completion date. Like everything else it competes for funds, manpower and priority. From the sounds of it, it should be nice once completed.
Did I see an announcement recently from EAA which said the township has voted against the new UL strip?
You would be correct. The township of Nekimi said no, but EAA is still working the issue. There is still the DNR issue but there might be some potential work arounds like shortening the proposed runway length.
