When installing an O-200 in my 7AC, I saw no problems in using the standard engine mount. Mind you, I did not use the Lord mounts, since they move the engine forward far enough to require a modification to the cowling. Instead, I bought a set of conical inserts off of Ebay and used them with the standard rubber bushings. It all turned out just fine and works like it should.
