FAA Webinar on Experimental Amateur-Built and Light Sport Aircraft
On Wednesday, December 7th, the FAA is holding a webinar on homebuilt and light sport aircraft.
https://www.faasafety.gov/SPANS/even...EventList.aspx
"We will discuss the different certification types and rules. What you should know and how to be prepared. Additionally we will discuss Airworthiness Directives and their applicability."
You have to sign up for it in advance, so act now.
Was the webinar high quality? Anything discussed that was not already well known?
