Thread: De-Registered Aircraft
Threaded View
  1. #3
    Order 8100.19
    You may be correct on this one and it needs to be parted out.
    One possibility I found seems to be through Order 8100.19. This seems to be a process buy which an aircraft is repaired to the point it could be registered again. It's not exactly the situation I have but it could be interpreted that way. In my case the "repair" could be the wing upgrade and inspection before registration.
