Results 1 to 9 of 9
Thread: Volunteering at AirVenture
    CarlOrton's Avatar
    DFW Area
    There are so many volunteer opportunities it’s impossible to list them all. Some communities are closely knit and it’s hard to break into those areas. Others are so short staffed, if you can fog a mirror you’re in.
    When you realize only about 35 of the workers are paid and the rest are volunteers, it’s easier to realize what’s available. One job I’ve thought of was to drive the golf cart around to the outlying spots to provide water, snacks, and sandwiches. You’d get to see the grounds, provide a break to folks, and get to sit.
    I’ve worked N 40 flight ops, helped park planes in HBC, departure briefings, and for about 10 years now in the Sheetmetal Workshop.
    Carl Orton
    http://mykitlog.com/corton
    Auburntsts's Avatar
    Tampa, FL
    Guys appreciate the responses. I get the part about the opportunities and when they get “advertised”. I was more curious about the volunteer process itself and whether there was any advice for a newbie beyond just pick the area that interests you and sign up.
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
    In general, each area of interest will have a team leader, they or co-workers will teach you everything you need to know to do the job required and you can mostly count on working with some great, friendly human beings who also share the same passion for aviation. Don't forget to pack your sense of adventure, sense of humor and patience.
    Hey Randy, is there a list of areas/POCs? I don’t recall ever seeing one.
    I did find this page on the AirVenture website which would be a good start- but it says it will not be updated until March, 2022
    https://www.eaa.org/eaa/support-eaa/...-at-airventure
    Vintage Flight Line can use volunteers at any time of the day the airport is open (6AM-8PM). We run training twice a day (9AM and 1PM, you only need attend one) every day. We have jobs from parking aircraft, directing traffic, crowd control, looking up aircraft, and so forth. No prior experience required. Work as little or as much as you want. This all goes down at the operations building which is a tan thing diagonally across the road from the Hangar Cafe.
    Vintage, in general, has a volunteer booth out in front of the red barn that can refer you to all sorts of other opportunities.
    They keep a list of wanted volunteers outside the RED BARN .
