I'm having difficulty with a radiator shroud I am trying to make. For some reason I can't seem to cut the hole in the shroud. I have tried placing holes on every surface of the shroud with no luck, I also tried boss bass and also no luck. Attached are examples of the errors I get when I try each operation.
Does anyone have any idea whats going on here?
