Hello and thanks for the info. I am fine with SW 2020. It took a second to realize I needed to go back to https://www.solidworks.com/sw/education/SDL_form.html to be able to select the 2020 option. Thanks for your help!
How long does it typically take for the EAA serial number? I submitted my request via the EAA website a couple of days ago and have not gotten anything. I checked my spam folder.
Oddly, the page says "Please fill out the form to access 3DEXPERIENCE SOLIDWORKS for Makers at a 50% discount".
Unfortunately I'm not the guy to speak to about this and I don't know who is![]()
So I have had it installed for a year and a half now but for some reason when I try I get a System Error "The code execution cannot proceed because VCRUNTIME140_1.dll was not found. I've attempted to modify and install the files I was missing but I keep getting that error. I then tried repair and I get "Internal Error: The Windows Installer for this product component did not run as exprected: INSTALL." It then tells me to contact technical support but I don't think we get tech support on the edu sooooo I'm kinda stuck here hoping someone has a clue. My version is good until Dec of this year.
Figured it out. Was a driver error. Updated latest windows and Nividia Driver. Dang Quadros are finicky.
I have not been able to find a link and instructions to download Solidworks. I sent an email to contact EAA and received this information: CSE: 4SX3J2, TKT: ocfRa0 and this link: http://www.eaa.org/solidworks which does not have links or instructions. SOLIDWORKS Info 2019.pdf I'm not sure how to proceed.
John
Hi John,
The new access instructions for SOLIDWORKS can be found here - https://www.eaa.org/eaa/eaa-membersh...-software-form
Once you fill out the form, you will be able to download a PDF with the instructions.
I hope this helps.
Thanks!
David
The hyperlinks in the pdf did not work for me. (There were no links)
does anyone have the download instructions for SW.
I purchased the license a month or so ago and deleted the email.
I want to load it on a laptop I just purchased.
Emails I have sent to Cory seem to to keep getting kicked back
Adam Rigden
EAA 1051976
You might have better luck sending a Private Message to David Leiting (see post #96, above, and click on his name). If that doesn't work, you might try calling the phone number that Cory listed in post #47, on page 2 of this thread; perhaps it will still ring in the correct EAA office.
I could be wrong, but I don't believe Cory is with EAA any longer. I have a vague memory of receiving an email or PM from him more than a year ago in which he told me that he was no longer an employee.
Eric Page
Map of Landings
