Thanks for your reply. I will start my SolidWorks journey and try not to learn things the hard way.
I infer from the above it won't be very accurate in the last case. What would you say is the most useful way to use SolidWorks for experimental aircraft, and what is more of a fools errand (simulating the whole aircraft)?
