Airventure Today Newspaper - Why Aren't Downloads Allowed?
I tried reading today's paper online, but even at full screen on my monitor, the text is very difficult to read because of the size. When I press Ctrl +, only the controls change size, not the document.
https://issuu.com/eaahq/docs/avt_072521
I would like to download it to read in a better viewer, but it says they are disabled by the publisher. Why are downloads disabled for a publication that is distributed free?
Paul: I was able to make it huge on my system...If you look to the right of the 1/48 bar at the bottom of the screen, there is a -/+ bar.....that's the zoom for it. At the far right is the rectangular brackets, that will make it full screen, then use the zoom to adjust further.
Thanks Craig,
I see what happened now. When I moved my mouse pointer off the document area, the controls disappeared.
It would still be nice to have the document available when I'm in a non-internet covered area, and be able to do a bit of copy / paste to put some items in our chapter newsletter.
Paul
I had no problem reading the document.
i want my thirty minutes back!
